Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: 3 phase grounding
Little Ed
01-07-2014 19:02:17
that would be true only if the green screw were going thru the block and pushing against a bare spot on the box. Surely that is not the case. There would have to be a physical connection, such as a wire run from the grounding lug to the green screw to achieve bonding. And the way I have always understood the posts of this nature, this should be done at the first box on your side of the meter, as in this case
01-07-2014 20:53:20
 Re: 3 phase grounding in reply to Little Ed, 01-07-2014 19:02:17
That is the case. The screw goes through the plastic and is threaded into the case. Yes, this is the first disconnect, so them being connected here would be correct as I understand it.
01-07-2014 19:17:32
Yep like on Mobile homes, you must have a disconnect on the pole and then you run 4 wires to the MH main breaker box.
On most regular homes the breaker box is the disconnect after the meter so the neutral and ground bond there.
