Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Oil shut off switch?
T in NE
12-25-2013 15:33:52
If you put one in a go-cart, it will also shut the cart off upon making a right turn, until you by-pass it.
George Marsh
12-25-2013 21:26:53
 Re: Oil shut off switch? in reply to T in NE, 12-25-2013 15:33:52
Many moons ago, like almost 20, my son just had to have a go-cart. I found him one that someone put a 5 hp briggs where the gas tank was attached to the carb. The go-cart was a solid frame, ruff as a cob. If you got going too fast in the yard, the gas would vibrate out of carb back to the tank. So for a few seconds, the engine would sputter, cart slowed down until the fuel pump in carb filled the carb again and away he went. Nothing you could do about it, but it was a nice speed regulator.
robert major
12-25-2013 17:59:51
Hi They don't like being mounted on HY Trux crop sprayers to drive the spray pressure pump either. The guy I worked for had a 13 hp honda it would kill the motor on rough ground as it thought the oil was low. The only problem with disconnecting the switch came the days he forgot to check the oil. The switch working would of saved the cost of the new motor, when it seized solid at full revs and spat parts all over the field. It was my fault it happened, until I pointed out I was away for 4 days, so he had run the sprayer and never checked the oil!, it needed topping up a little every 2 full days work. Regards Robert
