Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: dc stick welding
ejensen
12-23-2013 21:32:37
Old, I like your thoughts on 6011. Local welder who lives next to me thinks the same way you do about
6011 Pete uses 7018 a lot. I was cleaning my shop and disconnected the leads to my dc welder. A good one.200 amp 60% duty cycle. I think I had the electrode plugged into the positive side if the welder.
I've had a couple lessons from Pete Welty. I think he is on the web as he is considered an artist with metal
old
12-23-2013 22:00:48
 Re: dc stick welding in reply to ejensen, 12-23-2013 21:32:37
By the way back in the late 80s I took some college courses. One instructor wanted every body to have a name tag on there desk. At the time I worked at Tracker Marine as a maintenance man. So I welded up a name tag. I took an aluminum piece and then welded my name on it in tig. When I quit the class due to job and class problem he asked if he could keep that name tag and I told him yes since I had no need for it and could make more
old
12-23-2013 21:50:28
On DC you can go either way depending on what your doing. Reverse polarity seems to get better penetration the straight on most stuff. I use my Lincoln buzz box more then I do my DC machine but then the buzz box is a flip of the switch and the DC machine is a pull start 2 cylinder engine that does not pull over very easy
Ken-Pa
12-24-2013 02:46:26
 Re: dc stick welding in reply to old, 12-23-2013 21:50:28
Old , you say you do most of your welding with AC ? I do most of my welding with old Monkey Wards AC/DC machine connected to DC . It's been a great little machine that I bought back in the late 60s . I had no shop/garage until the later 70s so I kept my accet/oxy set & welder in the basement . So of course I did my welding under Gods ceiling . I don't think myself as a welder , but when I weld something together , it stays together . I learbed that during my welding how angle grinder is classed as a hobbiests best friend . An old buddy used to always say I sure could produce lots of grapes . Thru years of harvesting grapes , I have slowly gotten better & grapes don't appear much anymore .I use a lot of 6011 but mostly 7018 DC rods . I used to even use 7018 7/64 DC rods for welding tin for autobody repairs ; but then that size became non existant .I had also bought a nice Miller 110 Cricket XL back in the 80s which I've learned to enjoy using for welding tin .All my trades have been what's called : Hands-On experience . God bless & Merry CHRISTmas to all . Ken
old
12-24-2013 07:14:04
 Re: dc stick welding in reply to Ken-Pa, 12-24-2013 02:46:26
Yep I do most of my welding with an AC machine but then that is what a Lincoln buzz box is. The DC machine I have burns a gal and hour and is a pull start machine so hard to start and in the winter impossible to start unless your built like the hulk which I am not
Ken-Pa
12-24-2013 14:11:36
 Re: dc stick welding in reply to old, 12-24-2013 07:14:04
Yes , in that case of hard starting , I can undestand why you have settled with AC . Did you ever try finding a DC welder that someone is selling cheap ? I've seen some nice ones on Craigs List . If (and I Pray it never does) mine would bite the dust , I think I'd do most anything to buy another one . I once worked plowing a widow ladies driveway & she showed me her deceased hubbies huge commercial AC Lincoln welder very cheap . But being only AC , I turned it down . Maybe Santa will bless you with a small DC machine . Merry CHRISTmas to you Old . God bles, Ken
ejensen
12-24-2013 18:12:28
 Re: dc stick welding in reply to Ken-Pa, 12-24-2013 14:11:36
Ken-Pa,
I use my everlast dc welder for all my welding projects
IH2444
12-25-2013 14:47:41
 Re: dc stick welding in reply to ejensen, 12-24-2013 18:12:28
Just to confound everyone.
I weld almost exclusively with 6013 rods on AC welders.
No problems with weld failure after about 20 years of doing it this way.
ejensen
12-25-2013 16:12:56
 Re: dc stick welding in reply to IH2444, 12-25-2013 14:47:41
IH2444,
A friend of mine who worked in a pre fan metsl
shop told me he used 6013 all the time
IH2444
12-25-2013 16:41:48
 Re: dc stick welding in reply to ejensen, 12-25-2013 16:12:56
I have even welded cast iron exhaust manifolds with 6013.
Not real pretty and quite tedious but worked fine and never fell apart.
old
12-24-2013 15:43:14
Over the years I have messed with a lot of Mig and Tig welding plus the AC buzz box and the portable DC one. I have a flux core mig unit right now but do not use it much. So far really never have needed a DC welder but if one did come up cheap enough I might buy it
frankmn
12-24-2013 07:06:13
I have a miller cricket in my garage as well.
Ken-Pa
12-24-2013 14:24:26
 Re: dc stick welding in reply to frankmn, 12-24-2013 07:06:13
Is it the 110 ? I once lent mine along with the proper gas for aluminum & roll of aluminum wire . He had a Ford Mustang a guy was restoring to do repairs on . My friend promised to replace the wire & gas when finished . Well a hard lesson was had by me .My Grandson has screwed me after using my mig in my shop/garage . I've had it with trusting someones word , so never again . I worked hard to have what I have , so why let someone else cost me extra expense . Do you know Miller quit making this machine after 1 yrs production ? It was then replaced with the 130 .I hope you have enjoyed yours as much as I have ? God bless , Ken
Copyright © 1997-2015 Yesterday's Tractor Co.
