TractorLinks.com
Tool Talk Discussion Forum
Re: ATV battery...how long to charge?
david - or
12-21-2013 17:10:35
For best battery life you are supposed to do the initial charge at an amperage that does not exceed 1/10th of the battery capacity in amp-hours.
So for a smallish ATV battery of 5 amp hours the charge rate should not exceed 0.5 amps, hence the chart they gave you. Ideally it should take 10 hours to charge the battery at this rate.
If you go ahead and use the 2 amp charger anyway, the battery will still work, but you will cause some sulfating of the plates and the ultimate life may be compromised.
Assuming a very unsophisticated 2 amp constant-current charger, and assuming the typical 70 percent efficiency in storing charge, we would expect a 5 amp-hour battery to be fully charged in about 3.5 hours. Do not charge it any longer than that.
If the charger has a trickle or float mode, it will roll the current down as the battery voltage rises, and take longer to get to full charge. But in that case it should also limit the current to not damage the battery. Probably 4 to 4.5 hours should be the limit.
For a constant current charger, when the voltage with the charger connected rises to 13.8 volts or so, you are done. Don"t let it keep charging all night, or you"ll fry the battery.
PJH
12-21-2013 19:37:19
 Re: ATV battery...how long to charge? in reply to david - or, 12-21-2013 17:10:35
I'm certainly not an electrical wizard, but when I was a young man, I series/paralleled a couple of 1157 automotive bulbs off of our 20 amp power supply to keep our emergency battery pack charged on a ho-made ham repeater. It's been many years ago, but I "think" it allowed about 2 amps charge rate. I "think" each bulb limited about 1 amp, therefore two would get you around 1/2 amp, wired in series?
