TractorLinks.com
Tool Talk Discussion Forum
Re: long ratchet extensions
ben brown
12-18-2013 16:32:29
some one ex plane to me how a cheater on a click type torque wrench would change the torque i always heard that,, but getting old and 200 ft pounds is getting to be a challenge for a 150 lb old man.
NCWayne
12-18-2013 18:44:56
 Re: long ratchet extensions in reply to ben brown, 12-18-2013 16:32:29
Adding an extension to the handle end of the wrench, which I assume is what your saying, won"t change anything but the input force needed to reach the selected torque. Think about it like this, of your pulling 250 ft lbs with a 1/2 drive wrench that has a 12" long handle, x amount of force is needed to reach the selected torque. If you do the same 250 ft lbs with a 3/4 drive wrench that has a handle 36" it will take substantially less force to reach the same 250 ftlbs of torque on the output. That"s why they call the extra length a "cheater"....
On the other hand if you were to add anything to the other end of the wrench, say a crows foot wrench, etc. then the applied torque would change. In that instance, the amount of change would be dependent upon the distance of the fastener from the center line of the torque wrenches output/drive, just as the other posts have stated.
Now if you add an extension, in theory, the applied torque won"t change. Thing is if the extension doesn"t have enough torsional strength to not twist before the fastener reaches the selected torque, then the actual applied torque will be off, regardless of whether your using a clicker type wrench or a beam type wrench.
GUIDO
12-18-2013 18:20:43
Hello ben brown,
Changing the length of the torque wrench will change the torque applied.
Here is a picture of some torque values and what makes them change. The last pictures shows that the length is changed the torque applied will also change,
Guido.
GordoSD
12-21-2013 08:56:18
 Re: long ratchet extensions in reply to GUIDO, 12-18-2013 18:20:43
Not true. The torque will be more at the bolt only if you apply the same amount of force to the longer handle as you did the shorter handle.
JerryBowers
12-18-2013 17:41:45
It doesn't. The torque wrench will still click at the preset value regardless of the cheater.
GUIDO
12-18-2013 20:44:26
 Re: long ratchet extensions in reply to JerryBowers, 12-18-2013 17:41:45
Hello JerryBowers,
The formula is: Weight X Distance = force.
Torque wrench length X torque desired
Torque wrench Length + extension Length
Do the math!
Guido.
Stick welding
12-18-2013 22:44:13
 Re: long ratchet extensions in reply to GUIDO, 12-18-2013 20:44:26
There's a big difference between using a standard socket on a torque wrench with a cheater on the handle and having an extension where the socket goes on. I wouldn't call the latter a cheater. You're multiplying the force of the gauge by extending the socket center. I would call a cheater something to make it easier to pull to get the proper torque, whether it's a piece of pipe or a guy who works out and has strong arms. The torque wrench would have no way to know what was pulling it. Most torque wrenches are sufficient length to reach their capacity without the need for a cheater though.
GUIDO
12-19-2013 06:54:34
 Re: long ratchet extensions in reply to Stick welding, 12-18-2013 22:44:13
Hello Stick welding,
Its simple math really. Extension on the socket ZERO torque value change. Extension on the torque wrench change on torque applied proportional to the length added.
Guido.
Bob
12-18-2013 19:15:33
As to use of a "cheater", many torque wrenches are calibrated with the force applied at the center of the hand group. Doing otherwise makes them inaccurate.
(Or so states the instructions that come with most torque wrenches I've ever bought.)
