Yesterday's Tractor Co. We Have the Tractor Parts You Need
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Husky saw question
Richard G.
12-17-2013 08:29:56
74.177.99.212
My son has a 55 Rancher. It is a bear to pull the cord to crank. Years ago, I had a 55 with a compression release and it was easy to start.
His has the place on the side where one would have been put on. Is it possible to install one on his?
I can't find a local Husky dealer in the yellow pages, but I haven't tried very hard to find one.
Richard in NW SC
[Reply]   [No Email]
cannonball
12-21-2013 04:48:19
174.131.201.0
 Re: Husky saw question in reply to Richard G., 12-17-2013 08:29:56
Have a 266XP, cold starting is very hard to pull...Try pulling the 55 slow 2 times and then pull to crank
[Reply]  [No Email]
Bret4207
12-21-2013 04:53:56
64.19.90.196
 Re: Husky saw question in reply to cannonball, 12-21-2013 04:48:19
Cannonball- you own what is in my opinion the finest falling and general purpose saw ever built! My 266 died some years back and I've been trying to replace it for several years. They certainly hold their value!
[Reply]  [No Email]
55deere70
12-20-2013 17:31:48
66.189.10.65
Any man in shape enough to use a chainsaw should be able to pull over a 455 compression release or not. Like the other guy said, it's not a 288. Look for something else causing it to pull hard.
[Reply]  [No Email]
D beatty
12-19-2013 19:46:31
50.165.15.143
It could be done but you would have to pull the jug to do it right because the jug and head are one piece. By pulling it and doing it you don't have to worry about any metal getting down in engine. I don't know if it would be worth the time to do that.
[Reply]  [No Email]
T in NE
12-19-2013 19:01:32
75.239.101.198
Boss has a 455 with compression release. I've used it exactly once. The release, that is. I can't say it makes much of a difference.
Now on my 288XP it just might.
[Reply]  [No Email]
t.r.k.
12-19-2013 18:47:16
71.31.64.233
Some of those older Husqvarnas had problems with the recoil rope pulley warping. Then it would bind against the cover and be like putting the brakes on when you pulled it.
Take the recoil off, and remove the rope pulley and see if the rope slot is wider on one side. Also check the shoulder the pulley spins on and clean out any crap that is in there.
[Reply]  [No Email]
Richard G.
12-19-2013 05:59:30
74.177.116.126
Checked the saw and it has no plug where the release would go and is not threaded. The rope is original and not shortened. It is just a bear to pull the start rope. Runs great when cranked. Probably has less than 8 or ten hours on it.
Richard
[Reply]  [No Email]
Richard G.
12-18-2013 05:08:43
98.84.69.8
Thanks for all the ideas. I will take time to look at the saw today and get back with what I find.
Richard
[Reply]  [No Email]
jdemaris
12-18-2013 04:59:48
70.194.7.136
Does it have all its rope on the pulley? If it's been shortened - the circle it turns on is smaller, has less leverage and pulls a lot harder.
Sometimes the pull handles break off and the rope becomes shorter. I just got a saw for free that the owner was going to throw out because it pulled too hard. It's problem was just a short rope.
I have a 55 Rancher for an "el cheapo" saw. It pulls easy as compared to a Poulan Pro. I also have a "yard-sale" 455 I got for $50 and it does have a compression release which certainly makes it pull easier. The 455 is a plastic "homeowner" saw like the 55 Rancher so I assume the 55 would accept a compression release IF the jug is drilled for it. I never felt the need so I never checked.
[Reply]  [No Email]
Bret4207
12-18-2013 04:24:57
64.19.90.196
Have you tired something simple like lubing the pulley shaft? I sold dozens of 55's and can't imagine one being hard to pull due to compression. I bet the problem is in the pulley area.
[Reply]  [No Email]
Ian Beale
12-17-2013 17:57:53
58.169.191.166
I think you might find these don't have the head separate from the cylinder.
[Reply]  [No Email]
Rlpintx
12-17-2013 13:16:53
166.137.156.26
Think there are instructions on race saws page. Think you have to pull head, drill, tap and Debur hole on inside of cylinder.
[Reply]  [No Email]
ih_bug
12-17-2013 12:03:09
67.58.196.191
if it helps the 455 rancher has the compression release. the compression release button is only about $10. is the hole drilled and tapped?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
