TractorLinks.com
Tool Talk Discussion Forum
Re: JohnT?
Bus Driver
12-16-2013 08:26:29
To those who say they have seen shaded pole 1/4 or even 1/2 hp motors, what I know for certain is that I have not seen any of that size. A link to a website would be helpful.
Shaded-pole motors have very low starting torque and loads that require 1/4 or more hp probably could not be started by the shaded pole. It seems that split-phase might be the type that was actually encountered. Very common for 1/4 and 1/3 hp loads that are relatively easy starting. I have a shelf full of those in my shop. And most single-phase motors of 1/2 hp or more will use capacitor starting. Unless I see an actual "official" reference to larger shaded pole motors, I simply cannot believe that they exist. My beliefs, right or wrong, do not change reality.
Bob
12-16-2013 22:23:05
 Re: JohnT? in reply to Bus Driver, 12-16-2013 08:26:29
Here's a couple of examples:
http://www.hydromatic.com/resources/images/757.pdf
(See page 2.)
http://goodmanrepairparts.com/blower-motor-b1340002s-goodman-13-hp-shaded-pole/
(The replacement motor pictured MAY be a an improved PSC replacement, but the original B1340002 was DEFINITELY shaded pole.)
Dusty MI
12-17-2013 04:31:08
 Re: JohnT? in reply to Bob, 12-16-2013 22:23:05
Thanks for the info. I too had always thought of shaded pole motors as very small fractional hp motors.
Dusty
John T
12-16-2013 15:41:30
Hey Driver man, sorry I have no specs or data or info on any bigger then small fan shaded pole motors youre asking about. However I can tell you the ones designed for small low torque fan or blower motors dont have a very big winding because 1) It dont take much magnetic field strength to get it spinning and 2) They dont want to waste any more energy then necessary since it sits there and wastes energy even after running as it dont get switched out. HOWEVER theres no reason they couldnt have a bigger winding that draws more amps that develops more magnetic field to produce more start up torque that remains in the circuit so no switch is involved BUT THATS NOT AS EFFICIENT AS IF THAT BIGGER WINDING GOT SWITCHED OUT.
However, Im sure you already know all this and are just curious to see specs and data for higher torque requirement bigger HP shaded pole motors and I sure dont hold that against you. I learned years ago NEVER SAY NEVER so I don't say they are or are not available (likely are is my bet) but a place where you didn't care if they were less efficient because they were hard to get to and you don't want to mess with any switch headaches (like a well pump motor Bob mentioned) sure would be a good candidate lol
Fun chattin with ya
Merry Christmas
John T
