Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Wire Size for Kewanee Elevator Motor
11-26-2013 12:13:02
Silo unloader motor box will contain 2 , 3 or 4 capacitors with start and run functions. A local motor starter will be required at each supply receptacle. Don"t plan on plugging the elevator in live and under startup . 10awg would do but 8awg would be better as the code book calls for 32.5 amp minimum capacity. 70 amp non time delay fuse, 45amp time delay fuse or 60 amp breaker. Starter thermal size 30.0amp.
11-27-2013 08:15:45
 Re: Wire Size for Kewanee Elevator Motor in reply to buickanddeere, 11-26-2013 12:13:02
Thanks for the reply. I double-checked the motor last night and the box contains capacitors and a push-button reset(?) switch. To see a picture, use the link in this message.
For the motor starter at each receptacle, would that basically be an ON/OFF switch setup? I'm not that familiar with these larger motors (at least large to me) and not up on all a motor starter does, but trying to learn.
