Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: OT: Ford F150 battery ground
John B.
11-26-2013 07:44:44
You can buy the cable battery clamps that come with a pellet of solder and just cut an inch off the cable, clean it up, apply some flux to it, melt the solder in the battery clamp then insert the cable. Keep the heat on it for a few seconds after inserting the cable. I've used these for years and they have lasted a long time. Some cable can be hard to re-route once taken out. Cables usually only go bad at the ends. Corrosion can work its way back inside the insulation so if that is the case replace the cable.
Slowpoke
11-26-2013 18:10:25
 Re: OT: Ford F150 battery ground in reply to John B., 11-26-2013 07:44:44
The old cable is a #6 & is too small for a 60" length. The new correct one is #4 & 38".
