TractorLinks.com
Tool Talk Discussion Forum
Re: House boiler question HVAC experts?
Bob
11-25-2013 07:59:19
1. What do you have the "low limit" set at? That is the setting that controls the temp of the boiler when there is NO call for heat. Setting it as low as it goes (just over 100) will keep the boiler's standby temp as low as possible WITHOUT any electrical changes.
2. See diagram...
3. If you can disable that internal connection, the burner will only run when a zone valve is "open". From a cold start, the burner will fire when a zone valve opens and the circulator will NOT start until the boiler reaches the "low limit" setting. (This is for quicker heat exchange warmup to reduce moisture/acid/soot buildup in the heat exchanger.)
s.crum
11-25-2013 13:32:46
 Re: House boiler question HVAC experts? in reply to Bob, 11-25-2013 07:59:19
Ok thanks! I will look into this again on Wednesday.
