Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Table Saw Draws too Much Juice
11-25-2013 06:47:05
Two probable causes:
1. Bearings are dry or worn.
2. Centrifugal start switch is sticking. May or may not have one, it's a set of contacts with fly weights on it that keep the motor on the start winding until the speed flips the weights out and opens the contacts.
If you're confident in your ability, pull the motor off, clean it out good, check the bearings, and clean and lightly lube the centrifugal mechanism.
George Marsh
11-25-2013 14:22:25
 Re: Table Saw Draws too Much Juice in reply to Fawteen, 11-25-2013 06:47:05
Totally agree on both your points.
Adding a third point, if bearings or bushings are worn, the rotor will show scratches where it has rubbed against the stator. Look for scratches.
36 coupe
11-25-2013 14:38:29
 Re: Table Saw Draws too Much Juice in reply to George Marsh, 11-25-2013 14:22:25
Fixed a ball bearing motor that was slow.Bearings were ok but it had drag marks on armature laminations.Chucked the armature in a lathe and found it out of round.A light cut fixed it.
George Marsh
11-26-2013 04:43:30
 Re: Table Saw Draws too Much Juice in reply to 36 coupe, 11-25-2013 14:38:29
I've found the rotor out of round too. No one fixed things any more. Not many have lathes. They just chuck them and buy new. My lath is 65 years old and it still works.
36 coupe
11-27-2013 11:47:10
 Re: Table Saw Draws too Much Juice in reply to George Marsh, 11-26-2013 04:43:30
My lathe dates to pre 1934.Its an Atlas with a Sears name on the switch box.Dad bought it for 25 bucks in the 50s.Sears used to sell metal lathes and all the tools to go with them.My lathe has a broken gear in the apron.I have a gear to replace it.There must be some old lathes sitting idle.There seems to be little interest in machine tools now.
George Marsh
11-28-2013 11:54:53
 Re: Table Saw Draws too Much Juice in reply to 36 coupe, 11-27-2013 11:47:10
Mine is a 10 inch atlas, 3 ft bed. It's both a metal and wood lath. I don't use mine that much, but it real nice to have when you need to make something you can't buy.
