Yesterday's Tractor Co. Tractor Parts for All Brands
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Cutting Acrylic to size?
Jim in Ma.
11-25-2013 04:40:47
72.70.105.62
I have a sheet of clear 1/4" acrylic I need to cut to size for some side windows in a cab. All straight cuts. What tool would be best for that? - Thanks Jim
[Reply]   [No Email]
Zachary Hoyt
11-25-2013 18:29:28
184.10.222.196
 Re: Cutting Acrylic to size? in reply to Jim in Ma., 11-25-2013 04:40:47
Band saw for me too, regular wood cutting type.
Zach
[Reply]  [No Email]
dhamps10
11-25-2013 16:38:03
50.103.129.16
Band saw works best.
Dennis
[Reply]  [No Email]
flembo
11-25-2013 15:55:27
66.31.12.12
I agree with JRSutton I have cut up hundreds of 4'x8'x 1/4" sheets for machine guards using a table saw.Now with new management we send it all out to be water jetted I don't see how it can be cheeper but who am I.I could it if was odd shapes but it's all square or rectangle and occasionaly triangle.
[Reply]  [No Email]
missouri massey man
11-25-2013 12:21:09
108.90.234.133
It's fairly easy to cut with a Metabo and razor blade for cutting sheet metal and other thin materials. Essentially a 4" angle grinder with super thin blade....ergo "razor" blade. It'll kinda melt and curl up some of the off fall, but peel that off with a gloved finger then dress it down on a belt sander. It will work very easily. It's easy to form also if you carefully heat with a heat gun. Too much heat and it'll bubble and distort a bit. You're lucky...all straight and flat.
[Reply]  [No Email]
JRSutton
11-25-2013 11:12:11
100.0.77.120
table saw will work, it'll work best with a blade that lists plastics on the intended materials list.
But if you've got rounded corners, or anything other than a straight simple line - a sabre saw is probably your best bet.
Obviously leave the protective coating on until you're done cutting.
[Reply]  [No Email]
Jim in Ma.
11-25-2013 07:18:28
72.70.105.62
Thanks, It is Lexan. I will try cutting it with my 4" grinder with a thin cutoff wheel.
[Reply]  [No Email]
Bus Driver
11-26-2013 06:51:43
67.213.57.158
 Re: Cutting Acrylic to size? in reply to Jim in Ma., 11-25-2013 07:18:28
First you say it is acrylic and then you say it is Lexan. Lexan is a GE trademark (now SABIC Innovative Plastics) for polycarbonate.
Polycarbonate is much tougher and priced much higher.
Do not clean these materials with ammonia- which is in most glass cleaners.
[Reply]  [No Email]
Dirt
11-25-2013 07:12:43
75.148.34.117
I use my table saw with just a normal blade.
[Reply]  [No Email]
inkspot
11-25-2013 07:10:19
209.50.26.86
they sell a laminate blade to cut formica works great on the other plastic like sheets i have ine on my table saw great for plywood too
[Reply]  [No Email]
wile E
11-25-2013 06:57:01
75.129.76.76
I would highly recommend using a Lexan or other non-shattering polycarbonate sheet. Acrylic will splinter and crack very easily. Dont ask me how I know this.
[Reply]  [No Email]
tomturkey
11-25-2013 06:30:18
216.81.211.253
I've used a table saw with a carbide blade. Keep the blade as low as possible and still cut thru the plexi-glass, keep the piece tight to the table.Use you personal protective gear. gobble
[Reply]  [No Email]
JOHNNYfromMI
11-25-2013 06:28:14
74.115.62.217
I would think a chainsaw would cut it, but don't think you would like the results.
[Reply]  [No Email]
Router..John,PA
11-25-2013 05:28:28
209.163.120.173
I generally use my wood router with a "pattern" cutting bit. HTH.
[Reply]  [No Email]
showcrop
11-25-2013 04:49:31
75.67.231.80
I had to cut a piece a year ago and after a few tries with lots of cracking with various means I ended up using my grinder.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
