TractorLinks.com
Tool Talk Discussion Forum
Re: 3 phase question
DaveK(IN)
10-24-2013 10:11:56
You may want to look at the rate structure too. The three phase service will likely be a commercial rate and could also include a demand charge. this could make your residential use actually more expensive than a seperate single phase service. Also consider voltage drop loss from your shop to the house and the maintainence cost if it is your wiring.
Also, if you deduct the shop power as a business expense you will have problems with the IRS if the house consumption is not metered by a real electric meter. I did it the other way around and fed my shop from the house service through my own sub meter. I read the meters every Jan 1 and deducted the percentage of use for the shop from my household expense.
WyoDave
10-24-2013 11:24:47
 Re: 3 phase question in reply to DaveK(IN), 10-24-2013 10:11:56
Cost per kWh is the same. The 3 phase basic charge is more, but I want it for my shop anyways. The only thing is I will be losing the single phase basic charge. It isn't huge, but it adds up. Also, I didn't explain it very well. Both buildings will be fed separately but from the same meter location.
David
