Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Charging Electric Trailer Brake Battery
jon f mn
10-23-2013 19:05:56
You will have to do some checking to see how they hooked it up from the factory. Some hook to the power wire, some to the clearance lites. Both of those are not too good. The clearance lite idea can cause the fuse to blow if the battery is too far down. The hot wire method can charge too fast and overheat the battery. The ones done right will have a charger in the system hooked to the power wire so it protects everything. And some do nothing, thinking the battery is a throwaway. Without checking you won't know which method was used.
