Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: warm differential
nisse
10-06-2013 20:31:37
Thanks for the information, I will see how the yoke turns. When I took it apart I made a couple reference marks on nut and counted turns on the nut, also made a measurement with caliper to make sure I wasn't a turn off. Ended up about a quarter turn short when I tightened nut back up.
John
nisse
10-07-2013 07:42:59
 Re: warm differential in reply to nisse, 10-06-2013 20:31:37
I dropped the driveshaft and it isn't too tight if anything might be loose I couldn't really feel any drag. Can't hear any noise with stethoscope or driving except for a slight clunk when braking hard at low speed.
Thanks,
John
gab
10-07-2013 06:59:42
Whenever I repl. a pinion seal I center punch a spot on the pinion end, the yoke and the nut then tighten until they line up plus a hair more.
MarkB_MI
10-07-2013 02:10:07
Hmm. If it's indeed a quarter turn short, that would mean insufficient preload. You wouldn't even be in contact with the crush sleeve, and the nut usually needs it a bit tighter than before to compensate for bearing wear. I'd expect the rear end to be noisy if you didn't get enough preload, due to pinion gear movement.
