Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Reducer to garden hose for the threads on a 250 gal tote
JDemaris
10-06-2013 05:50:40
I've seen these tanks all over the south and north-east and all had the thread setup I described. The shut-off valve (if there) has the pipe threads. Not the tank. The ones I'm talking about are the same as in this ad.
John in La
10-06-2013 07:43:18
 Re: Reducer to garden hose for the threads on a 250 gal tote in reply to JDemaris, 10-06-2013 05:50:40
Just because that is the only one you have seen; or it might even be the most common; does not mean that is the only one they make.
The tank will have a buttress thread. 6mm thread for the 2 inch size or 8 mm thread for the 3 inch size.
To this you can screw on many different valves. American 2 inch valves will most likely be NPT but if the tote came from Europe it will be a 2 inch buttress thread.
You can buy adapters that adapt 2 inch buttress to 2 inch NPT so you can use American pipe on it.
Then they have that crazy 3 inch china valve. It looks like NPT but is not the same. I find it easier to just replace the valve with one I can work with.
