angle grinder
Anonymous-0
how do you check tah armature andor field on a electric motor or can it be done with oms meter angle grinder quit running brushes are good
Hello inkspot,
Check the voltage at the brushes. That will eliminate the cord and the switch. Make sure the armature is clean and the brushes make full contact. Also make sure that both brushes are touching the armature,
Guido.
