TractorLinks.com
Tool Talk Discussion Forum
Re: steel entry doors with steel casement?
Jason the Red
09-29-2013 08:18:04
Search "commercial hollow-metal door frames". If you go this route, a three piece knockdown frame would be your best bet for replacing your existing door. However, this style frame would require drilling and dimpling for additional fasteners for your security requirements. Keep in mind these frames are typically meant to be installed with the wall sliding into the throat of the jamb. Therefore your wall thickness will dictate the frame you use. You can case the opening, then slide a welded frame into that opening and attach the frame to your casing. This requires "slugging" the frame with morter or concrete first. One advantage to going with a commercial door is the use of commercial hardware, which is far superior to residential in quality and security. I hope this info helps.
Hope this info helps.
