Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: steel entry doors with steel casement?
09-29-2013 07:27:41
To get a steel frame, you will have to get a commercial steel entry system. The rough opening sizes are different than for residential systems so probably not a good solution. Menards sells them on a special order and they are expensive. You can put a piece of flat iron on the outside of the frame with the proper holes drilled in it and it will make your door more secure. If someone wants in, they will get in anyway.
Wile E
09-29-2013 07:53:36
 Re: steel entry doors with steel casement? in reply to frankmn, 09-29-2013 07:27:41
Yes, But, making it more difficult to get in is important. Crooks want easy quick access. I have a home alarm system. I also have a doorwall that is wedged shut with a 2x2 piece of wood. I have deadbolts, but the front door and the wood frame in my opinion will not stand up to an attack. Helping to prevent a break-in is a start. Having a home safe also helps. Thanks for the info.
