Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Building a Motorcycle Trailer
Stick welding
09-28-2013 10:19:10
What are your welding skills? I've seen some home made trailers that I sure wouldn't want to be following. A trailer, especially for an expensive bike, isn't a project to try out your new welder. If you're trying to build it on the cheap with scrap you have laying around, you're setting yourself up for failure. If you have the skill and want to build it, don't cut corners and build it right.
T in NE
09-29-2013 09:33:06
 Re: Building a Motorcycle Trailer in reply to Stick welding, 09-28-2013 10:19:10
I've seen scrap piles that would allow for several trailers that size to be built. Just because it's the scrap pile, doesn't mean there isn't good material in it.
Stick welding
09-29-2013 10:27:53
 Re: Building a Motorcycle Trailer in reply to T in NE, 09-29-2013 09:33:06
Then they aren't really scrap piles are they? I've seen some stuff built from scrap piles and it makes you shake your head. If I wanted to build a trailer, I would use the right materials to build what I wanted rather than use what I had laying around. You might have some materials you could use but substituting smaller and weaker material isn't a good idea.
Glenn F.
09-29-2013 10:45:17
 Re: Building a Motorcycle Trailer in reply to Stick welding, 09-29-2013 10:27:53
Not being arrogant, but nothing "smaller or weaker" comes out of my shop.
Glenn F.
Stick welding
09-29-2013 21:48:04
 Re: Building a Motorcycle Trailer in reply to Glenn F., 09-29-2013 10:45:17
All too often the case when someone wants to build something for cheap with what they have laying around. Instead of spending $50 or $100 on new steel, it's more of a this will be good enough attitude. You are talking about a building a complete trailer out of old materials for $100 and it won't be smaller or weaker? Good luck with that. Decent tires and rims will cost over $100.
Copyright © 1997-2015 Yesterday's Tractor Co.
