Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Building a Motorcycle Trailer
jon f mn
09-27-2013 10:51:39
Do yourself a favor and buy a 2000lb torflex axle. It will be easier to mount and more reliable and give a better ride. Get 5 on 4 1/2 bolt circle so you can easily get replacement wheels when you blow a tire. The small tires will haul your load fine but turn several times faster going down the road so tires and bearings don't last as long. You can help that by checking the air in the tires frequently. Those small tires don't need a big leak to loose a large % of their air and low air pressure is the leading cause of tire failure. Also the biggest reason for bearing failure is sitting time. If you leave your trailer sit for several months the bearings rust where the grease is rubbed off then when you start driving they fail. If the trailer is sitting for a long time just go out and push it around a bit from time to time to move the grease around, that will help.
