Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Kohler engine
ken combs
09-27-2013 09:41:17
The flywheel side shaft is a bolt on item. Available from Kohler to add to your engine.
41106
09-27-2013 11:22:01
 Re: Kohler engine in reply to ken combs, 09-27-2013 09:41:17
I should explain a little better. I've located a zero turn that has a bad engine but price is very cheap. Current owner says cylinders are too bad to rebuild. So if I understand you correctly, basically any 27hp kohler horizontal shaft will work and I could bolt on other side?? I realize I'm kind of putting the cart in front of the horse, but wanted to make sure I'm not buying something that is an odd ball set up. Thank you for your input and would welcome more!
Gene Davis (Ga.)
09-29-2013 19:03:59
 Re: Kohler engine in reply to 41106, 09-27-2013 11:22:01
Can you not put a sleeve in the cylinders and bore to std. size.
Truck
09-27-2013 19:30:42
What kind (make and model)of zero turn are we talking here?
