Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Orifice Cleaners
soundguy
09-26-2013 17:05:36
go buy a set of strings for a 6- string ( guitar ).. best (cheap ) money you will spend on a carb cleaning tool. :)
GUIDO
09-26-2013 18:39:35
 Re: Orifice Cleaners in reply to soundguy, 09-26-2013 17:05:36
Hello soundguy,
I did not know that strings came that small.
Copper strands has served me well for many moons. I like it because is soft, and does not enlarge the hole. The last jet I needed to clean I guessed at about .014. Just blowing to clean these small orifices is not usually enough,
Guido.
soundguy
09-27-2013 14:25:10
 Re: Orifice Cleaners in reply to GUIDO, 09-26-2013 18:39:35
a guitar high E string will be as small or smaller than a single strand of that copper.. and will be strong enough to need high quality wire cutters to cut it. as 36 said. soft ductile copper strands can break off in a small orifice or port. that guidar sting is tough.. and long. if a end gets worn.. cut off a bit. single string can last a lifetime. a set of 6 ( E A D G B E ) and you have many choices of size and style )
36 coupe
09-27-2013 02:11:53
You stand a good chance of breaking the copper off in the jet.
GUIDO
09-27-2013 12:16:13
 Re: Orifice Cleaners in reply to 36 coupe, 09-27-2013 02:11:53
Hello 36coupe,
Here is how I clean some smaller the heck jets!
Blowing does not always work..........
Guido.
spacecadet9
09-27-2013 00:23:58
Quoting Removed, click Modern View to see Plain (unwrapped) steel guitar strings run from .007" to .026"
GUIDO
09-27-2013 12:19:06
 Re: Orifice Cleaners in reply to spacecadet9, 09-27-2013 00:23:58
Hello spacecadet9,
Did not know that, thanks. Are the smaller ones single strand? Multi strands work like a charm!
Guido.
soundguy
09-27-2013 14:27:49
 Re: Orifice Cleaners in reply to GUIDO, 09-27-2013 12:19:06
the smallest are usually single string. however you can get wound types in many sizes. the would types can have round or flat profiles too, depending on base wire and wid wire.
a small wound wire makes a GOOD cleaner
GUIDO
09-28-2013 10:20:48
 Re: Orifice Cleaners in reply to soundguy, 09-27-2013 14:27:49
Hello soundguy,
Thanks, I thought that the smallest sizes would be single strand....
Guido.
504-1
09-26-2013 18:56:22
I have used strands too. One of the best things I have found is a "hand drill tip cleaner", they run about $10.00 at any welding store.
GUIDO
09-27-2013 12:22:55
 Re: Orifice Cleaners in reply to 504-1, 09-26-2013 18:56:22
Hello 504-1
Are you talking about these?
The smallest one was to big for the jet I was trying to clean...........
3 wires .004 each twisted together did the trick!
Guido
Copyright © 1997-2015 Yesterday's Tractor Co.
