I have a Power Pro log splitter made by Brave Model HP-1226F. It's working but not correctly. The valve in the forward stroke position is fine. If I pull it back to retract the ram it used to go into a detent position and stay there until the ram was fully retracted and then the handle and valve would return to the neutral position. It now sticks if you put it into the detnet position and you must pull it forward into the neutral position. You can feel it stick in the rear position as you pull it forward, although it goes into the detent position smoothly. Any idea of what is wrong and can the valve be disassembled and repaired fairly easily? I might add that this log splitter does not get a lot of use. Maybe a few times in a year and then just sits around.
Thanks,
Bill
Thanks,
Bill
