Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: welding question
M w J
09-24-2013 20:51:42
If it is cast iron don,t try to weld it with oil in it will pit the weld and leak. Drain the oil and heat it enough to burn the oil out of the crack but you might have to heat a fairly large area. Then use nickle Rod and it will work better then most other things stronger the brazing.
welding man
09-25-2013 15:30:23
 Re: welding question in reply to M w J, 09-24-2013 20:51:42
I totally disagree with that. The nickel is stronger than brass, but the cast in the heat affected zone of the weld will be more brittle and will crack quicker than if it is brazed. No the weld won't break but the cast beside it will be even weaker than before.
