Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: welding question
NHBalerman
09-24-2013 19:33:57
OK that is the answer I was looking for is to weld opposite of the crack,not parallel,it is on the side of the header just mild steel that the wobble box bolts to,also found a housing that has a little slack at the bearing that I will fix for the vibration that caused the crack,Thanks for the help
RodInNS
09-25-2013 05:39:37
 Re: welding question in reply to NHBalerman, 09-24-2013 19:33:57
If this is just the mild steel frame of the machine, don't worry about it. Bevel it out and weld parallel to the crack with a 7018. No question about it. Run a couple more passes to add a good crown over it and leave it. I wouldn't plate it.
Rod
jon f mn
09-24-2013 19:39:30
Reread what I wrote, I edited a bit and that should help more.
