Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: WONT START! Miller WildCat 350D WELDER
RuralTowner
09-24-2013 16:15:06
Well, new fuse in the Murphy and sending unit (looked identical to the one removed). Still no start but the light will BLINK now. That's an improvement. <sigh> At this point now I think the Murphy Box isn't working right. Even in daylight I should see diesel smoke coming out the exhaust when cranking until it starts. There is none. It ran briefly on a spritz of WD40 but died almost immediately. Hopefully its as simple as the Murphy just not sending power to the injector solenoid. Disconnecting the oil switch and using a different one was probably the last straw for the box...that foil wrapped fuse probably never helped either.
Getting some professional help tomorrow to better troubleshoot the issue before going further. Hindsight, the PITA it is, had me recalling a stubborn seen-better-days workhorse of a diesel mower from last week. The fuel cut-off solenoid wasn't working fully...if only partially in it ran slow: The welder (the last time it actually RAN) ran slow just the same instead of revving up to its standard governed 1850RPM.
I apologize if I come off as "derr" (buck tooth, cross eyed cartoon character comes to mind), about this but its frustrating enough for myself since I bought the welder and would have to cover any repairs. Even worse for dad since it was my finding the welder that made it a godsend to help in the shop. What might take an hour and maybe a gallon of diesel beats the hell out of MANY hours and half a tank of acetylene (oxygen doesn't go as quick).
JD Seller
09-24-2013 21:02:43
 Re: WONT START! Miller WildCat 350D WELDER in reply to RuralTowner, 09-24-2013 16:15:06
You hold the override switch down to get the engine to start. Then you keep holding it until the oil pressure is up and then you let go.
On these systems you should hear the solenoid click when you push the over ride button down. They really are not that complicated to deal with.
RuralTowner
09-25-2013 15:46:44
 Re: WONT START! Miller WildCat 350D WELDER in reply to JD Seller, 09-24-2013 21:02:43
JD Seller said: (quoted from post at 22:02:43 09/24/13) You hold the override switch down to get the engine to start. Then you keep holding it until the oil pressure is up and then you let go.
I hear the "click" but still wont start on its own. Did enough cranking that the deep cycle battery I got for the thing is started to chug a little bit. Oil//Temp light would blink out when cranking so it IS getting pressure. Needs a spray in the air breather to even kick over. At this point I think that Murphy box is being temperamental. After discovering the wire layout I checked for power at the injector pump terminal with a test light...nada. I get continuity but thats it. In a short bit (within the next hour of this post) will be getting that assistance spoken of.
At this point I just need to know if the thing will still run, and want a more experienced hand just-in-case if I have to bypass the Murphy because of an electric fault in it.
EDIT: All is working back the way it was after first purchasing the welder and using it from time to time. Appears to be an issue somewhere between the oil pressure switch and the Murphy...annoying but far better than all seemed before...but fully intend to trace down.
Still plan on installing real gauges though as addons under the engine cover.
This post was edited by RuralTowner at 18:58:17 09/25/13.
