RuralTowner
Since a strong welder is no doubt of use I've come here for some assistance. Since its a diesel...and I'm no diesel mechanic...I'm sure more than a few people here have forgotten far more about said engines than my limited knowledge. I understand the basic function but thats it.
As said in the title its a 350D Wildcat circa 1980. Goes up to amperage beyond anything I'd use it for. At the same time it wouldn't be out of place in places such as big oil platforms and upper end contractors (private or otherwise). Picked it up last November for $1800...quite a bit cheaper than I've seen them go elsewhere.
The problem: It won't run now. Also now the oil//temp light comes on.
Was using it earlier today briefly but as soon as I noticed a significant oil leak coming from the oil pressure sending unit. Turned it off...and hope I didn't hit the kill switch at a bad point.
Nearly broke the stem on the sender (has to have it to clear the oil filter mount). Had to rig up a replacement stem and used a spare non-specific sender unit. By this time this was done the engine had cooled enough that it was going to be a hard start. With myself at the switch//push button I had dad give it spray of starting fluid onto the air filter element (its mounted horizontal on top of the welder. [b:4b9a724742]NOTE: I wasn't paying attention and he sprayed enough so the air filter element dripped! I sure hope it wasn't overdone.[/b:4b9a724742] Got it started and it seemed to run rough (use earlier was fine). The oil//temp light had come on.
Now...the welder has a safety switch in it to auto-shutdown if temp gets to high or pressure too low. However was able to get it to run again after trying the OLD sender but still the light was on and it ran nowhere near like it did BEFORE killing it when noticing the oil leak. [b:4b9a724742]Could a damaged sender be causing an issue where it doesn't know if it wants to stay running or not?[/b:4b9a724742]
I'd just as soon bypass the safeties so proper gauges can be installed...never liked dummy lights.
Also...when turning the OFF//RUN switch to RUN...only the AMP light ever came on before and would go off once it got running. Turns out after looking at the manual I found for the welder...that the OIL//TEMP light should be on too with the switch in RUN with engine off. That light didnt ever come on until AFTER the sender leak//fix was done. [b:4b9a724742]IF its a matter of a working sender to make the safety system work proper...would a common oil sending unit work in its place and HOPEFULLY keep the safety shutoff from semi-tripping?[/b:4b9a724742]
