TractorLinks.com
Tool Talk Discussion Forum
Re: WONT START! Miller WildCat 350D WELDER
JD Seller
09-22-2013 21:51:50
I have several questions and observations:
1) What brand of engine does this welder have on it??? Miller does not make engines they buy them. With the model of engine you should be able to match a sender to motor.
2) Why not just buy the correct sending unit for your welder??? That way the safety system would still be intact. You really need that on a welder. You are welding not standing there watching the gauges. I would get the auto shut off working before I used it much.
3) Why the heck would you be using ether on motor when it is this warm out side???
4) You very well could have damaged the motor with ether. The smaller the diesel the less either you can use safely. I have seen bent connecting rods and other internal damage caused when either was used on small diesels.
This post was edited by JD Seller at 19:14:44 09/23/13.
Stick welding
09-22-2013 22:29:07
 Re: WONT START! Miller WildCat 350D WELDER in reply to JD Seller, 09-22-2013 21:51:50
It's ether not either but it could cause major damage if the air filter was dripping! That's beyond excessive. It's probably a good thing it didn't start. If the welder has a Murphy switch set up and it had an oil leak, it's supposed to shut down. If parts for the Murphy set up are broke, they need to be replaced with the correct parts, not something that will fit. That could be the exact reason it won't start.
Never heard of 350 Wildcat before. I'd guess the engine is a Perkins or a Continental as that's what Miller has used in Trailblazer 55D's that are 350/400 amp machines. They have also used other engines. Sometimes people with no experience with diesels or machines in general should REALLY get a manual and perhaps find someone with experience before they try to do anything with it. The poster may have just cost himself a few thousand dollars in unnecessary repairs.
