guido
Hello,
This trimmer is 1 year old, and boy does it have a problem! It is very hard to get started, and will barely run at full throttle. Let the throttle go, and it dies! I cleaned the carb, and checked the fuel filter and lines so far, no problem found and no change. Any of you ever had such a problem? It did lock up ones, so I took the plug off and pushed the piston down. Never did it anymore, but is sure needs more help!,
Guido.
Guido.
