TractorLinks.com
Tool Talk Discussion Forum
Re: Welder Question of 3 days ago revisited
George Marsh
09-17-2013 06:21:10
Not sure if your genny will work. My 3500 watt genny has an RV outlet, 110v and 30 amp rated, that might work and might damage genny. How much do you like your genny?
Leroy
09-18-2013 06:53:49
 Re: Welder Question of 3 days ago revisited in reply to George Marsh, 09-17-2013 06:21:10
Only requires a 15 amp breaker and that is what the generator has. Is it clean enough power? Computor works OK on genny.
36 coupe
09-19-2013 03:40:44
 Re: Welder Question of 3 days ago revisited in reply to Leroy, 09-18-2013 06:53:49
Running a computer on a gas generator is risky.Problem is over voltage.I have found some generators putting out 130 to 135 volts on light loads.Back to welders.I was looking thru a 1952 Popular Mechanics magazine.Plenty of little welders advertised.The 4 Way welder was 19.95.My father in law gave me one.He got it from his brother who said it made the wiring smoke in his shop.That welder has 2 coils of resistance wire.The electrode holder can have 120 volts AC on it open circuit.I never used it because I dont want the high side of the AC line in my hand while Im kneeling on the ground.Gloves do get wet and have thin spots from wear.20 bucks was half a weeks pay for many people in 1952.The 4 way Welder was a ripoff in that time.The 70 amp 120 volt welders are still being sold.You have 2 of them that dont work .If you only weld a few hours a year you will never be a good welder.A friend who welded for a living told me that by the time you are good at welding you wont be able to see good enough.I have tried the little welders,They just dont work well.A 1/16 welding rod is hard to control.An author of the book Aircraft Welding said this.Dont try to use a cheap wire welder, It will sour you on welding and make you give it up.
