NorthStar water heater
Has any used this tool which can be coupled with a pressure washer to have hot water when cleaning equipment? I was wondering how good a job this would do. Thanks
If you have hard water you will soon fill it up with calcium unless you run a filter/cartage on the inlet side. It adds some chemical to the water to make the scale not build up.
I don't know what tool you are looking at. I ran another copper tube to an outside facet next to my outside cold water facet. Added a Y hose adapter to them and mix the temp I want.
Look at your pressure washer closely, alot of them are cold water only, the cold water cools the pump and even warm water destroys them. chris
I got an old steam cleaner I converted to heat the water. You will have to run cold water from your power washer into the heating unit. I have a 3000# pressure unit and I have 150 degree water output.
(quoted from post at 19:39:23 09/15/13) Look at your pressure washer closely, alot of them are cold water only, the cold water cools the pump and even warm water destroys them. chris
Yupper! That's a fact.
I'm on the lookout for a steam jenny. Every time I find one I can afford I'm already broke though!
I have a lot of time into trying to repair my son's FIL's pressure washer. It is a low end Toro, and the check valves are plastic. Running for a little while without cold water running through distorted three of the six.
