TractorLinks.com
Tool Talk Discussion Forum
Re: welder question
RustyFarmall
09-15-2013 10:58:10
On the part about being able to see better. I had the same problem. Finally loosened up my wallet a bit and bought one of those auto-darkening helmets. Now I can find the best part of my tri-focal glasses to look through and focus on the work, and then just start welding. Before, with a conventional welding helmet, I always lost track of exactly where I wanted to weld while going through the motions of dropping the helmet down.
RayP(MI)
09-15-2013 13:31:09
 Re: welder question in reply to RustyFarmall, 09-15-2013 10:58:10
What Rusty sez... I had similar experience. I hate head mounted helmets that drop down. But at least with auto darkening, I can see where I'm at to start. Always used to use hand held helmets before. Better but still not the best. With auto darkening, I still like to flood work with a 300 watt halogen work light. I suspect my welder instructor friend would have a field day at my expense, but you gotta do what you gotta do...
Stan in Oly, WA
09-15-2013 13:45:04
 Re: welder question in reply to RayP(MI), 09-15-2013 13:31:09
Ray,
Have you had any trouble with weld spatter hitting the bulb and blowing it out? That happened to me while I was trying to illuminate the work area with a conventional incandescent bulb. I know halogen bulbs are much hotter than regular incandescent bulbs, but I don't know whether they're hot enough to be immune to weld spatter. Weld spatter must leave the weld puddle at over 2000 degrees F. But I don't know how hot the molten metal is by the time it hits something a couple of feet away, and I don't know how hot the surface of a halogen bulb is.
Stan
36 coupe
09-15-2013 14:47:52
 Re: welder question in reply to Stan in Oly, WA, 09-15-2013 13:45:04
Use one of the outdoor fixtures that had a plexiglass cover.Mount it on a pipe with a lamp dimmer and an ac outlet in a duplex box.The dimmer will let you run the lamp at reduced power to lengthen lamp life.Weld the pipe to an auto rim.If you are sharp enough to use 2 pipe sizes you can adjust the lamp height.
Dusty MI
09-15-2013 17:23:07
 Re: welder question in reply to 36 coupe, 09-15-2013 14:47:52
When I started wearing trifocals I went to the large window welding helmet. I have one now that also is an auto-darking.
RustyFarmall
09-15-2013 13:38:21
I like the idea of the floodlight. Seems like the older we get, the more light we need.
36 coupe
09-17-2013 02:05:48
 Re: welder question in reply to RustyFarmall, 09-15-2013 13:38:21
You need a spotlight type bulb to put the light right on the weld.
Leroy
09-15-2013 13:37:22
I think that is what I am going to have to do. have tryfocals and allso auto darkening helment
