Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: GM wiring??
Jo Bird
09-12-2013 05:36:41
First thing I would do is charge the battery and load test it.. then get the car started and check the alternator out put..all the electronics in the car make it tough to look for shorts with the old bulb between the negative battery post and ground. More than likely the battery is beyond it's replacement time.
T in NE
09-15-2013 09:44:26
 Re: GM wiring?? in reply to Jo Bird, 09-12-2013 05:36:41
Ideally a fully charged 12v battery will show 13.2 volts. Once started if the alternator is OK you should have about 14 volts, also check voltage with full electrical load (A/C, lights, radio, defrosters, etc, on) and you should still be over 13.2 volts.
