Brad Buchanan
Hey folks.
I am in the process of installing a new injector pump on a GM 6.5 diesel.
The lines were open for quite a while and I decided to remove them and blow them out before installing the pump.
I noticed that one of the lines had scale rust on it and I wirebrushed it and as the surface was irregular decided to measure it.
The upper portion of the line which is bright plated measured .251 in. consistently. The corroded portion varied from .241 to .251 in.
Does anyone know if there is a standard for this? Should this line be replaced?
Am kinda new to diesels so any help would be appreciated.
Thanks,
Brad
Thanks,
Brad
