I have an older Curtis two stage air compressor. It has the centrifugal air dump system on it. It doe not work without me fooling with it every now and then. I want to just switch it over to a normal unloader/dump valve setup. I would just disable the current system so the compressor starts to pump as soon as the compressor turns. Then install a unloader/dump valve in the supply line from the compressor to the tank.
My question is this. Where do I get a large unloader/dump valve??? Also do you see any reason for what I am doing to not work???
I have a Speed Air compressor that is much newer and this is how it is plumbed.
