TractorLinks.com
Tool Talk Discussion Forum
Re: Sears table saw/ will not run// rant
MarkB_MI
08-29-2013 16:52:14
Voltage drop is the killer of table saws. You have to be sure you have a circuit that can provide 20 amps with very little voltage drop, otherwise the saw is sure to burn itself up cutting tough wood. If your son is using a 15 amp/AWG14 circuit, he'll probably burn it out again. 12 gauge wire is a minimum, and if the saw is in an outbuilding, the feed to the building needs to be big enough supply 20 amps with minimal voltage drop.
36 coupe
08-30-2013 03:55:05
 Re: Sears table saw/ will not run// rant in reply to MarkB_MI, 08-29-2013 16:52:14
25 amps will run a 5 hp motor on a 240 volt line.Dull saw blades cook motors.
MarkB_MI
08-30-2013 18:23:06
 Re: Sears table saw/ will not run// rant in reply to 36 coupe, 08-30-2013 03:55:05
Which may be true but has nothing to do with the matter at hand. This is an inexpensive direct drive saw, probably rated 15 amps @ 120 volts. Try to feed it with an undersized circuit and it's going to burn up.
36 coupe
09-01-2013 03:54:46
 Re: Sears table saw/ will not run// rant in reply to MarkB_MI, 08-30-2013 18:23:06
Those cheap saws are worthless and anyone who uses one aint wrapped too tight.
