Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Sears table saw/ will not run// rant
Ken Macfarlane
08-29-2013 14:14:20
Got one sitting in the shop that the switch to kick on the start cap is bad and the new parts are super expensive. I suppose you could rope start it if brave?
36 coupe
08-30-2013 03:49:34
 Re: Sears table saw/ will not run// rant in reply to Ken Macfarlane, 08-29-2013 14:14:20
I have a few start capacitors in my shop that cost 6 to 10 bucks.Hardly super expensive.Sears has a 30.00 minimum shop charge.I used to charge 3 bucks plus part to change a capacitor.
Ken Macfarlane
08-30-2013 04:44:11
 Re: Sears table saw/ will not run// rant in reply to 36 coupe, 08-30-2013 03:49:34
Hi Its not a bad cap, that would be easy, its the current switch affair that switches it out of circuit when amps drop. Wasn't available here so I got an electronic one but it doesn't seem to sense and switch right.
Wiring is wonky on these saws vs a normal 120 v motor too.
The windings test out at right resistance but won't start right.
36 coupe
09-02-2013 03:01:42
 Re: Sears table saw/ will not run// rant in reply to Ken Macfarlane, 08-30-2013 04:44:11
Resistance dosent prove much on motor windings.Amp draw will tell you more.
Russ from MN
08-29-2013 17:01:51
I have one motor with a momentary contact push button switch for a starter, that would work fine on a table saw, for people that understand motors. Otherwise there are external load sensitive start switches, I have one of those on a grinder, I think it came from an old fridge.
Copyright © 1997-2015 Yesterday's Tractor Co.
