TractorLinks.com
Tool Talk Discussion Forum
Re: Delay on make timer?
buickanddeere
08-28-2013 14:00:34
Used to use pneumatic timers in control panels before PLC's took over. They could be set to delay closing the contacts on the application of power. Delay opening the contacts in the application of power. Delay closing the contacts on the removal of power. Or delay opening the contacts on the removal of power. Probably some in a relay control catalog somewhere? Just spin the little thumb wheel to vary the timing.
George Marsh
08-28-2013 14:07:44
 Re: Delay on make timer? in reply to buickanddeere, 08-28-2013 14:00:34
The TD60 timer is a cheap adjustable timer, 0.8 - 8 minutes and the voltage range is like 18 vac - 220 vac, however this is just a timer to be used to control a relay. Commonly this timer is on A/C.
I'm looking for a simple all in one, timer and relay, to handle a refrigerator.
So, is there criter like that?
Dr. Walt
08-28-2013 19:39:42
 Re: Delay on make timer? in reply to George Marsh, 08-28-2013 14:07:44
George:
Potter-Brumfield Time Delay Relay. Depending on which model you purchase the delay can be set for Seconds, Minutes, or Hours. These are on OCTAL plugs so you will need an Octal socket to mount them on.
