The water pump on my Allis Chambers 2900 series engine just went out. The Allis folks say the pump is no longer available because the company that used to make them went bankrupt. The good news is they have a rebuild kit in stock. If the housing is not damaged the current pump can be rebuilt.
How do you get them apart? Do you need a shop press? or can you heat the hub and impeller to get them apart? Does the hub the fan blades go on come off first? Or does it matter.
The kit comes with impeller and shaft and roller bearings, and seal.
