TractorLinks.com
Tool Talk Discussion Forum
Re: poulan saw
Mel in SW Iowa
08-11-2013 18:10:43
If I remember to remove and replace the oil cap when I put it away releasing the pressure in the bar oil tank, my two Poulan's seem to not puke it out nearly as bad. I think any change in temp will pressurize and push some of the oil out though.
Bret4207
08-12-2013 07:07:05
 Re: poulan saw in reply to Mel in SW Iowa, 08-11-2013 18:10:43
Depending on which model Poulan you have, you can try fixing the leak. The biggest issue I've had in my shop is that Poulan fits a slightly small hose into a slightly big hole and expects the oil to stay put. This is the fitting leading from the tank to pump line. I've fixed a couple by making a new fitting, another by using parts from a different saw I had laying around and one with JB Weld. In the end there's no easy fix except to find a bushing of some sort to fit the tank hole to provide a tighter fit.
