TractorLinks.com
Tool Talk Discussion Forum
Re: spraying latex paint
Bill in IL
08-08-2013 10:28:11
An airless would be the way to go for spraying latex. They sure are slick machines. Don't waste your money on a wagner. To spray with air you will need to thin your paint to get it through the gun.
Ronald Anderson
08-08-2013 16:24:50
 Re: spraying latex paint in reply to Bill in IL, 08-08-2013 10:28:11
Don't buy the cheapest Wagner sprayers as they don't do a good job. Get one with 1/2 horse or bigger motor. I started with a 1/4 hp and diaphram pump then switched to a piston pump sprayer that has 7/8 horse[power motor. It can handle the larger nozzles so you can do the job faster. With the airless there is less drift then using air compressor type. You can adjust pressure to a certain point but there is a learning curve and masking windows etc is a good idea. The wagner piston type is a good unit and will last a long time with reasonable care. Having said that my commercial unit cost 2800.00 versus 600.00 for the above model Wagner so there is a big difference in quality as well as cost.
