TractorLinks.com
Tool Talk Discussion Forum
Re: Magnetized pipe
Stick welding
08-02-2013 23:35:21
Probably drill stem. Try welding toward your ground or wrap the ground cable around it a few times. If you're using an AC machine it won't matter cause you won't get arc blow. That's about the only time AC has an advantage. You could also use smaller rods.
Ultradog MN
08-03-2013 03:28:15
 Re: Magnetized pipe in reply to Stick welding, 08-02-2013 23:35:21
Agree about winding the ground around the pipe a few times. Sometimes it helps to wind it clockwise or counter clockwise. Sometimes more winds, sometimes fewer. Play with it as every pipe is different.
Drill pipe gets magnetized pretty bad sometimes.
Never had a chance to try AC though.
All we had were Lincoln Pipeliners - all DC.
bill in colo
08-03-2013 09:33:29
 Re: Magnetized pipe in reply to Ultradog MN, 08-03-2013 03:28:15
Thanks for the replies. I have a Pipeliner and old century AC machine I have not used in years.Pipe is production tubing 2 7/8. I will try the wrapping method.
