Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Wood preservative
Billy NY
08-02-2013 08:16:29
Stan, some interesting reading below, it make sense given the material you are using, though I was of the same opinion of Mark, you can't get CCA as easily, I am not sure how the current ground contact material performs, CCA worked just fine, I used to handle it, crystallized CCA on the outside, wore gloves, and you don't want a splinter of this in you, or burn, eat or what have you, and I agree with it not being a good idea for playgrounds, but... people just being ignorant, fueled by some sort of activist movement directed towards the EPA, was likely the cause, I think you can order CCA though, see the links below, its still in use, but limited, and though not banned by the EPA, the wood preservative manufacturers seem to be in some sort of agreement about its limited use, as we do live in such a litigious and seemingly at times, ignorant society, no doubt as to why it went this way. ACQ and CA are the latest treatments available, I am not well versed in either, I do wonder if the ground contact preservative used today will perform the same if so, fine, but why is CCA still the choice for industrial use, it was everywhere for years and years. Same thing with creosote, fools ruined its availability, you can't dig a hole and fill it with creosote to soak logs with, like they did I am sure, its fine to use and use properly, I had some left over from years ago and applied it to the bottoms of 70's era 6"x6" x 18' posts, that have been in well drained ground for 7 years, to help prevent rot or decay, seems to work fine, no leaching ever, grass and weeds grow right up along them.
08-02-2013 09:09:59
 Re: Wood preservative in reply to Billy NY, 08-02-2013 08:16:29
In NY state you now need a pesticide applicators license to apply many wood preservatives that are only sold industrially.
Pressure treated wood really only absorbs treatment in the sapwood, so when cut thru there is hardly any preservative in the heartwood---thus the need to treat cuts and bolt holes.e always specified 3 separate coats of preservative to cuts, and the use of a pressurized bolt hole applicator for the bolt holes.
Billy NY
08-03-2013 05:20:45
 Re: Wood preservative in reply to dpendzic, 08-02-2013 09:09:59
I believe I read that about the applicators license. The thing is with fresh lumber from the plant, its great to use right away, but its still saturated, its hard to figure even with a pressurized applicator how it will absorb the preservative. If you dry the lumber, smaller dimension does like to warp. Large dimension, timbers and poles maybe not so much.
I can recall how heavy those units of lumber were. We had a delivery one day and the derelict, and or drunk forklift operator, popped a band on a unit of 2x12x16's on the opposite side of the trailer, with one of the forks, releasing most of the lumber onto the driver who was rolling up straps on the other side, and of course it was the top unit, he was crushed and severely injured, nice fresh CCA saturated boards.
There used to be blue and red tags, red was .60 CCA, I remember seeing that in 12"x12", I had bought a cut off from a yard I delivered trusses to.
08-03-2013 11:08:45
 Re: Wood preservative in reply to Billy NY, 08-03-2013 05:20:45
most of the projects I was involved with were for shoreline structures---NYSDEC required us to have a 30 day air dry time before using. Needles to say a lot of lumber was returned as it exceeded the warp, twist and straightness specifications.
