TractorLinks.com
Tool Talk Discussion Forum
Re: Tire help
Mike Kork
08-01-2013 01:00:05
It is OK to stick a tube in tubeless tire.
Dick L
08-01-2013 05:56:15
 Re: Tire help in reply to Mike Kork, 08-01-2013 01:00:05
I always put a tube in a tubeless tire going on an farm implement or farm wagon. Never crossed my mind not to. I have even put tubes in tubeless tires on a car when the wheel does not seal properly. What could be the down side other than the extra price of the tube?
KEH
08-01-2013 05:16:17
When a tubeless tire is mounted on a rivited rim, air leaks around the rivit holes, right? You could take the tire off, weld a bead around each rivet, carefully, grind smooth, paint(heavily over the welds) and mount tubeless tire. Sometimes the valve stem hole for a tube type rim wont accept a tubeless valve stem and the only option then,AFIK, is to weld the hole shut and drill a new nole for the tubeless valve stem.
Another possible option is to use the spray undercoating on the inside of the rim. If air still pushes out around the rivets, try duct tape around the inside of the rim. A tube is easier but more expensive.
KEH
