What tool do I use
Ted in NE-OH
I am over hauling my tractor generator. I have turned the commutator and now need to under cut the mica. I know they make a machine to do this but I don't have one. Any suggestions as to what tool to use or technique to use.
Thanks.
If you used a lathe to turn it use same lathe to undercut. Grind a tool to the correct width and set to depth. With the brake or other means hold the chuck steady while taking out a bit of the mica with the carriage handwheel. That's how I do it.
