Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Firearm ? Marlin 783
ken combs
07-31-2013 10:46:41
The two grooves in the receiver take a standard 22RF scope mount. Nearly all 22s made in the last 40-50 years have the same system. Some scope makers also make a set of adapter rings to mount a better 1" tube scope on those grooves.
Billy NY
07-31-2013 11:05:09
 Re: Firearm ? Marlin 783 in reply to ken combs, 07-31-2013 10:46:41
Thanks Ken, I figured it was likely a common arrangement, I did not know the name or nomenclature to search it. I'll get back to it when the new extractor arrives, sight in the iron sights, then likely put a scope on it for the longer shots, then post back about it.
GordoSD
07-31-2013 19:26:13
 Re: Firearm ? Marlin 783 in reply to Billy NY, 07-31-2013 11:05:09
If you mount a scope your iron sights will not be usable. Exception being the really tall see through mounts which are NOT suitable for .22. If you think you will be shooting in low light, or dark conditions, then get an inexpensive 4X power scope. Tape a scorpion type light to the barrel. That's my sweet corn coon gun. The other is my first gun, a 1950 H&R single shot .410 3 inch 4's are deadly and it has a pair of scorpions on it. I probably would work well at night for marauding raptors perched about the place but I wouldn't know about that.
Billy NY
07-31-2013 20:59:00
 Re: Firearm ? Marlin 783 in reply to GordoSD, 07-31-2013 19:26:13
Right again, I have that option on my M1A with a 3rd generation mount, but even with the inexpensive scope on it, I have taken many deer in low light situations, it sure gives you more opportunities in low light, even better if I had the illuminated reticle, red dot, range finder springfield used to offer. I figure until I get what I need for the 783, I'll get familiar with shooting it, iron sights, then more than likely install a scope, spring time I can nail a few 'chucks early and can see them easily at much longer distances, try to get this population down, now is tough as they are elusive enough and sure are persistent at times.
The best flash light I have ever used and is suitable to mount, is a MXDL SA-T68, sold on ebay, the barrel of it is machined flat, I can illuminate easily 100 yds out, its an LED with 3 levels of power, strobe and SOS to signal for help, foreign made but there is literally nothing as bright, if it reflects off something its blinding.
Copyright © 1997-2015 Yesterday's Tractor Co.
