Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: air line
IH2444
07-31-2013 05:07:02
If you do run the line underground, sleeve it inside another larger piece of roll pipe.
the airline will flex with each on and off of the air at the users end and will wear a hole or many holes in it as it rubs against stones and such.
Hal/ Eastern WA
07-31-2013 10:14:40
 Re: air line in reply to IH2444, 07-31-2013 05:07:02
I have very rocky soil, so whenever I bury any type of line, water, electrical or whatever, I sleeve the line with PVC conduit. It comes in 10 foot sections and is easy to work with and not too expensive. I do not use any glue on the joints.
Damage from rocks is a real concern. Also damage from burrowing rodents, although my cats seem to do a pretty good job of keeping rodents away from the buildings.
I think if I was going to run an airline underground that far, I would sure look closely at PEX. PEX is not that expensive and seems to work very well for water pipe. I would want to research how well PEX stands up to oils, since most compressors put some oil in the air over time. You don"t want to have to redo the job in a few years. Good luck!
Copyright © 1997-2015 Yesterday's Tractor Co.
