TractorLinks.com
Tool Talk Discussion Forum
Re: Calling JohnT and BD!!! Sub panel issue!!!
Bob Bancroft
07-27-2013 10:57:04
What do you recommend on a farm such as mine with several sub panels, each fed with three wires, all buried cable a LONG way from the main panel? No animals. No trouble. Ground rods at all locations. Apparently code has changed since my installations. It appears all neutrals and grounds are hooked together in all panels.
John T
07-27-2013 11:16:26
 Re: Calling JohnT and BD!!! Sub panel issue!!! in reply to Bob Bancroft, 07-27-2013 10:57:04
I recommend you do NOTHING, thats the way the code was for yearsssssssssssssss, it was likely legal when installed and maybe Grandfathered in by your local authority??????? In those days for 120/240 volt single phase three wire you only ran 3 wires to the outbuilding, 2 Hots and Neutral, just the same as the utility ran the twisted triplex 3 wires to your home. Then the Neutral was wired to a suitable GroundING Electrode and Neutral and Ground busses (if it even had two) were tied together.
But do as you please, I wouldnt be too anxious to raise any red flags i.e. dont ask dont tell and keep under the radar. Sure as you ask some bureaucrat and bring it to his attention he may call the SWAT team and the EPA and OSHA and run out and shut you down lol
PS Im always preaching do it right and safe, but while I believe the new 4 wire system to be better, the old 3 wire arent any great hazard in my opinion provided correctly installed and good earth grounding BUT IF A NEW INSTALLATION GO WITH THE CORRECT MODERN 4 WIRE
My opinion only, your choice now
John T
Bob Bancroft
07-27-2013 12:01:30
 Re: Calling JohnT and BD!!! Sub panel issue!!! in reply to John T, 07-27-2013 11:16:26
As always, thank you John. Indeed, I see questions asked on here that make me wonder if the SWAT/EPA/OSHA/NSA/etc. isn't going to come after us freedom loving rednecks! I'm not about to dig everything up. Short of adding a wire, by my limited understanding, there's nothing else to do. I just wondered if there was something that could be done at the panels.
