Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Calling JohnT and BD!!! Sub panel issue!!!
Greg 2N (TX)
07-27-2013 06:17:15
Great! You have the safety grounds run separate.
Now you have the ability to easily make the sub-panel ground attach only to the box ground bar for equipment ground.
All panels have the neutral bar isolated from the box, just like the hots are isolated from the box. The only difference is that the main panel ties the neutral bar to the box with a strap or a green screw.
Remove the bonding strap or green screw in the sub-panels.
Make sure the sub-panel neutral is connected to isolated neutral bar and the safety ground is connected to the box grounding bar alone.
And yes if you can afford the GFCI's at the waterers, then go ahead, but eehhhhh......
Amen again....
Greg
Greg 2N (TX)
07-27-2013 06:26:16
 Re: Calling JohnT and BD!!! Sub panel issue!!! in reply to Greg 2N (TX), 07-27-2013 06:17:15
BTW you may have to get some grounding bars for sub-panels that do not have one. Not a big deal, i trust you can do it.
Always make sure the mains are off, NO SHORTCUTS or HASTY DECISIONS with 240 volts brother.
240 volts means serious business.
Be careful or get an electrician if you have butterflies about it.
Regards,
Greg
Copyright © 1997-2015 Yesterday's Tractor Co.
